Re: RPM and WOT questions
AT 3200 rpm is was about 14 mph according to the gps. Never timed the getting up on plane time. When we first got the boat before we replaced everything it would run about 22 mph according to the gps. We did not have a tach then. New engine and tach now.
The hull is clean and is fiberglass.
The carb is new and a new fuel tank as well. A 2300 holley 500 cfm is the carb with a new arrester. New water separator and fuel filter and gas lines. New plugs(gaped per service manual), plug wires, coil, dist, electronic ignition.
The first run we took it out the boat ran around 3900 rpm. We were in the river and hit something floating under the surface of the water and it bent the prop. Took it down to 3200 rpm. Took the prop and had it serviced professionally but the boat still runs only at 3200 rpm. We took the boat offshore about 20 miles one way and on the way back home the carb started messing up and then the rpms went down to around 2600 and the gps said we wee running about 7 to 12 mph at different times. It bogs down real bad in swells.
