Re: Merc Controls
No, you will have to have the cables, and I BELIEVE a bracket, but if you are buying it new, just tell them that is what you are doing, and they will sell lyou what you need. Now, if you are going to go the used route, you will need to do more research. Hopefully someone on here that has done it will happen up on this thread and tell you for sure.
You are going to have to do something about steering as well, obviously, and they have links on the front page to companies that do that as well. I can tell you this much, it won't be what I would consider cheap to do this project. I'm betting close to $500 by the time it is all said and done, unless you go the used route on everything. Esp. if he decides to get tilt and trim too.
