i have a 1989 2stroke yamaha pullstart outboard and it starts on the 2nd or 3rd pull for the first time of starting the motor it runs great then about 10 min or so I shut it off or sometimes when backing off the throttle it will stall then I try to start it again and it will not start sometimes after pulling and giving it throttle at the same time and about 50 pulles it will sometimes start. If I wait a couple of hrs or the next day it starts up again on the 2nd or third pull no problem then it starts the same process over again. It seems to be getting fuel the ball gets hard and i can see the fuel going into the fuel filter and as the moter runs i can see the fuel leavine the filter and flowing in from the pressure side. the problem did start after i filled the tank up with more gas could it be the gas to oil mix? I put 2 gal of gas and 6 oz of 2stroke oil, please let me know youre thoughts on this problem thanks.
