RetroVintage
- Aug 11, 2008
- 7
I have a 1979 glasply with mercruiser and the trim pump went out.
I replaced the motor/pump, wired it all back the same as before now the down button works but not the up/out buttons.
I am thinking it is the trim limit circuit. I disonacted the bullet connectors going out the transom since the trim limit wiring on the outdrive are completely corroded/destroyed - up buttons still not working.
To completely bypass the trim limit - do i need to remove those bullet connectors and tie those wires together? there are three (two on one bullet and 1 on the other)
thx
thx
