Re: what should compression be on a 3.0L?
It sounds like it is a bit high unless the gauge is off. Do you have someone elses gauge to try? Only thing I've heard that would cause a high reading, is allot of carbon build up. Normally, not an issue on 4 strokes. Were the plugs black? How has you engine oil consumption been? I use seafoam sprayed into carb, to get rid of it on my 2 strokes.
