As, the title says, I have a '59 Seahorse 10hp. Seems to run very well, it idles smooth. I even have it idling so slow and low it sounds like it will stall -but it doesn't. And I can run it for 2-3 hours non-stop, but, I could've sworn I was closer to 27mph last season.
The only thing that has happened is at the very start of this season I overheated the engine due to a failed thermostat [i had the boat in the water not 10 minutes, idling, then WOT, then white smoke within minutes]. White smoke came out of the cowling and the engine stalled. I replaced thermostat and then did all of the below.
The boat it is on is a 10'4" Achilles soft-bottom inflatable with just me [180], 3-6 gallons of fuel, and 30 lbs of gear/safety equipment. I've tried;
different angles on the transom
different seating positions [with a tiller extender]
hydro-stabilizers [from W-lm-rt]
different fuel
carb teardown
fuel pump teardown
I've pulled the head and seen no visible water leakage from the copper ring [don't have a compression tester] then torqued the head bolts slightly more than what it took to take off. No difference in power output
I've reversed and ground [to "square-ish"] the clutch dog [so that it doesn't jump out of gear anymore]
I SeaFoamed it and got an extra 2mph [from 15 mph to 17mph] via higher RPMs.
Now again, she idles/runs just fine, she just doesn't go very fast anymore.
Now that I think about it -at WOT she sounds, "tinny" a little high pitched, 90% throttle sounds "better", "warmer" with a slight reduction in speed.
Also on rough water, when I am bouncing over waves, the engine drops RPMs for a second, then comes back up.
Any ideas from you gurus?
Thanks!
ill13
different fuel
carb teardown
fuel pump teardown
Thanks!
ill13
