also you need a y pipe and the strings for the side mounts for the 4.3 where as te 3.0litre had the front mount
the mounts are different and so are the gears in the outdrives. It is doable, but much easier, and usually cheaper to sell boat and buy another with motor you want
Looking to race it?
the only way to do the 4.3 swap would be to buy a complete donor boatI'm pretty sure i'm done with my boat buying.
A 4.3 is not really a great engine for trying to get two adult skiers up anyway. Nor is a 17 foot trihull. For that matter why do you really want to get two skiers up at the same time?
Sounds reasonable and after doing some reading the 4.3 can produce pretty good H.P., up to 300 H.P. with out breaking the bank. I like the idea of a slightly smaller engine, length and weight that can make an easy 250 + H.P.
Keep in mind that you only have 5000 RPM or less to play in. Also, you are looking for power in the 2000+ RPM range. If you have the boat propped for 50 mph at 4800 RPM, and want to ski at 25 mph, you can see at 25 mph you will be at pretty low RPM. Peaky motors need not apply.
http://www.hotrod.com/techarticles/engine/113_0208_chevy_43l_262ci_v6_engine_build/index.html
This article at Hodrod.com shows a healthy 4.3, 9.08 compression, and the torque curve is pretty flat. It's making 194 HP, 292 ft/lbs at 3500 RPM and 285 HP and 311 ft/lbs at 4800 RPM. If it makes over 200 ft/lbs at 2000 RPM, I'd say you have a winner.
