will not go in geear
capt1325
i had a water pump go out and overheated the engine. Fixed the water pump and restarted the engine. Only problem is that when ever shifting to forward or reverse motor dies. With the motor off can shift into gear and the prop still spins freely. What could this be?
fishinpa
Re: will not go in geear
diesel / gas or hybrid ?
renault / dodge or datsun ?
:eek:
lol yes a lil more info for the minds here
make model year , engine size or what ever ya can give !
welcome here !
fish
Ayuh,.. Welcome Aboard,.... What drive,..??
capt1325
sorry should have put this in first post it is a 1990 Mercruiser 4.3 v6 with an alpha 1 1st gen drive it is a gas motor.
capt1325
well the drive will go into gear found a rubber fuel line from carb to fuel pump bad. now the boat will shift into gear but now the prop does not go in forward or reverse. could the shift shaft not be connected correctly upon reinstall after changing the water pump? 90 alpha 1 4.3 engine
NHGuy
If you follow the shift adjustment procedure in the alpha 1 manual (free download in Adults only section) you'll either fix the adjustment or find the problem.
