I have a 1973 Johnson 115 that I have put on a 1996 Four Winns w/ a blow Johnson 115. I used the 1996 mid-section and engine cover (so I could have tilt & trim) My problem is that there does not seem to be enough air getting to the carb. The motor revs very high with the cover off, then will die when the cover is put back on. I dont see anywhere for air to get inside the cover, except through the small opening around the exhaust cover. I also have to take the cover off and spray starting fluid into the carbs, for cold starts, even w/ the choke locked open. This model Johnson does not have an adjustable air/ fuel mixture adjustment, They have the high and low oravices. Any thoughts or suggestions appreciated.....
