Mark42
- Oct 8, 2003
- 9,334
I started pulling out the carpet from the Bayliner. Today I was able to get an hour or so in on the boat, and with my son's help, we pulled the lounge seats, removed both upholstered side panels, and removed as much of the carpet as I had planned to replace.
One thing I realized is that the carpet came out in nice big pieces without tearing or ripping, same as it was glued in. I quickly realized that is a BIG help, because the old carpet pieces are perfect templates for cutting their replacement pieces from the Deco Dot vinyl. So we carefully removed all the pieces, including seat bases, flotation boxes, and some hull pieces. They were marked "Port" or "STARBOARD" and rolled up and saved. These old pieces will save me hours of making templates from craft paper.
Hope this helps someone else who is replacing carpet.
Also stopped at Lowes and picked up Stainless Steel staples labeled "Suitable for Marine Use". ($16 for a small 3x4" box!!!) Be careful when buying stainless staples, because there were others labeled "Not for Marine Use".
Will post some pics as the project progresses.
