sidenberg
- Mar 2, 2010
- 206
engines runs best with idle mixture screws turn out 3/4 from lightly seated. Any richer than this it runs to rough at lower rpms,(vibrates and intermitten skipping). I understand this setting may be considered too lean, however it runs smooth at this level, (although still tends to smoke somewhat within the lower rpm range) and, shows no sign of overheating. So it seems the proper amount of fuel is entering the cylinders. I have noticed the idle mixture screws are somewhat rounded at the tip instead of sharp. Could this be the reason of the 3/4 turn setting? If not, what other things may have an effect on an engine needing such a lean idle setting? Timing?
