Fishmaster07
- Jun 13, 2010
- 3
I have run into a bit of a problem with my boat. I have a 1994 Stratos 201 Pro powered by a Johnson GT 200. The last time I took my boat out it ran fine until I went to make my last run back to the ramp. The engine started fine, idled fine and everything, but when I went to take off before it could get on plane it kinda bogged out on me. I immediately noticed that my fuel gauge was low so I switched tanks over. However after that my motor wouldn't stay running. It would start and run for about 20 seconds before it would shut off. So I used my trolling motor to get back to the ramp. I changed the spark plugs and went to start the boat, and it wouldn't even turn over. So i tested the battery and saw that it had weak charge, replaced it and it turned over. However, now when i turn the key the thing won't turn off. The motor just keeps turning over. I hit the kill switch and everything and it won't shut down, I have to take the wires off the terminal. So had anyone encountered a problem like this? would it be that my starter is just sticking or the solenoid is bad? Time for a new starter? If you have any suggestions, I would greatly appreciate the help. thanks
