Motor will not start until flammable liquid is sprayed into carb. After cutting motor off, can restart easily unless several minutes have passed. Then must again spray start fluid into carb. With motor not running and tilted up, noticeable fuel mixture comes out from lower part of carb, dripping in front of transom. Motor runs well after starting. Anyone know how to correct my problem?
