fuel leaking
mike45
fuel squirts out rear of float housing where the top part of housing sits on bottom. Is their a gasket that might be cracked or something?:confused:
5150abf
Re: fuel leaking
Sounds like it, get this fixxed before you start the engine again, gas in an enclosure with fire is really bad.
You can get a sheet of gasket material at any auto parts store and make your own if you don't want to wait for the part.
mike45
Re: fuel leaking
1995 115 evinrude, took float cover off, rubber gasget fits in groove on bottom section of housing looks good
