worked fine last fall
Digby1965
new to the forum maybe you guys can help me. I have a late 70,s johnson seahorse I beleive it is a 35 horse anyway the starter spins but the gear on top will not rise up to engage the flywheel I have never had any trouble with this motor and it was working just fine last fall when I winterized it!!
Please help I would really appreciate it
Thank you
Digby
kenmyfam
Re: worked fine last fall
Bad connection or bad battery. Clean all connections both ends. You can try a little lube on the bendix as well to be on the safe side.
Welcome to iboats
