mhansard_1
- Apr 14, 2009
- 12
I have a 1976 150 inline 6 stuck in the up position. I have replaced each trim and tilt cylinder and the motor stayed up while I drained oil, removed lines and replaced each cylinder. It doesn't appear to be locked in the up position. Is there another mechancal lock other than the port and Starb locking tabs?
Note: Trim and tilt did work prior to replacing the cylinders, but very slowly and took a long time. Any help will be appreciated.
