93 Johnson 150 GLETR
I hit the throttle, she got up on plane, I started trimming up and then something gave. The RPM's jumped and it just stopped. Engine continued running fine but I shut it down quickly. Shifted to neutral, restarted, put it in gear....and nothing. I have no forward or reverse but motor seems to run and rev as usual. It just won't go
Got it home and removed the prop...found a bunch of gear lube behind the prop. I Drained the lower unit oil and I've got a ton of water and metal flakes. I changed the gear lube about 2 months ago with new o rings and it has not been leaking or taking water as I have checked it a few times.
I would like to get any input on where to start with diagnosing and possible rebuilding...what do you think happened? thanks!!
