Hi,
Am having trouble starting a '81 Johnson 6 hp. I have sparks on both plugs when held against the block, and fuel going all the way up to the carb. What I don't have is any sign of life when I pull the starter rope. Not even a cough, sneeze or splutter. I tried squirting some fuel into the choke butterfly valve, still no joy, not a pop. The sparks I'm getting from the original plugs (L77JC4) look pretty weak - thin and white/yellow in colour. Could it be as simple as needing new plugs, and if so, which ones?. Any other suggestions on what to try next would be much appreciated.
