bsutravis
- Jun 11, 2010
- 64
I'm dealing with a '77 Mercury 1150 / 115 HP outboard:
Last night while running at near top speed, without any warning or unusual noises the boat seemed to come out of gear and the RPM's skyrocketed. My hand was already on the throttle so I instantly yanked it out of gear thinking it had jumped out of gear or something. Once it was in Neutral I put it back into gear and I could hear the normal sound of when it engages, and the boat starts to idle forward, however when I eased down on the throttle the prop doesn't spin beyond the spinning that I had when it was idling, only the engine revs. I get the same thing when I put the motor into reverse.
I started limping the boat back toward the boat ramp and eventually I lost even the idle speed.....like the prop TOTALLY stopped spinning, however there was heavy boat traffic and the waves were rough so I killed the motor and we anchored and fished for a little bit till sundown when I could just run the electric trolling motor back to the ramp. So, after the boat sat for 90 minutes I start it up and put it into gear and once again I have good idle speed, and could even idle up SLIGHTLY and gain a little more boat speed as I went back to the ramp.
This morning I went out with the boat still on trailer / not running and put it into forward gear. I could spin the prop clockwise and I could hear a loud "CLICK CLICK CLICK" but it sounded like it was supposed to make that noise...very distinct, not some weird grinding click. When I put the gear into revers I have a SOLID lock on the prop as I try to spin it clockwise and counter clockwise.
Any thoughts? I'm thinking/hoping that the hub is slipping under the weight of the boat in the water, but it grabs enough in idle that it moves the boat before the RPM's are raised to the point that it just sort of free spins on the prop hub.
Any info or experience is greatly appreciated.
