convergent
- May 17, 2010
- 385
Have a fish and ski boat that is new to me and the prior owner didn't know the answer to this question. There is a switch panel on the bow that I'm trying to figure out and wondering how its probably wired. The boat has 2 x 12V batteries in the stern compartment that have a Perko master switch on it. When this is on, both batteries work. When its off, all power is off. I usually keep this off when at home and I have my in-boat charger wired straight to the batteries.
Now to the panel on the bow. The first switch is 3 position... I have been leaving it in the middle. It has a "Charge 2-12V" setting, and a "Run 12/24V" setting. I am pretty sure that with it in the center "unmarked" setting, the boat charges both batteries because after I have been out all day and return and hook up the onboard charger, the batteries are not in need of charging. So I have no clue what those other settings do, or how they are wired to the batteries. I also don't know if the master switch was there from the factory, so possibly some overlapping duties here??? If no help is available here, I'll eventually spend a raining afternoon trying to trace the wires. But from the bow to the stern will take some effort. So any ideas?
The last switch seems to control what the gauge on the right shows for voltage. If the left switch is in the center where I leave it, then the gauge will show a voltage reading when put in "Battery 2" position, but shows nothing on the gauge when in "Battery 1" position. It does the same if the left switch is down. If the left switch is up, however in "Charge 2-12", then moving the right switch to "Battery 1" or "Battery 2" will result in a reading on the gauge. This also seems to work regardless of whether the red master switch is turned off or on, so these front panel battery switches are bypassing that master switch.
It bugs me to not understand what the switches do and how they are supposed to be used. I have an electronics degree, so if I could find a wiring diagram then that would be helpful, but Glasstream has been defunct for years and no clue where to find a diagram. My assumption is that this is probably a common wiring setup that exists on other boats so maybe someone here could help me figure it out before I start trying to climb into to tiny spots to explore (and possibly break something that isn't already broken).
