Colortune???
Cut2Short
Anyone ever heard of a carburetor tuning tool called Colortune??
I?ve been really struggling on getting my 1988 Mercury 150hp XR4 to run the way it?s designed, while I?m still waiting for the carb kits to get delivered, I was talking to a friend who has a device called a Colortune. Supposedly, it has a glass sparkpug unit that you can see the different combustion colors (yellow being rich and bunsen burner blue being balanced, and white blue being lean) and fine tune the air/fuel mixture ratio by adjusting the various jets. I was hoping to find a little advice on how this tool worked and maybe the best way to use the tool. The literature says to do all of the testing at idle, but I was thinking of keeping it on the trailer, putting the motor in the water, placing it in gear and try running it through the various throttle positions. It comes with a little black tube with a mirror to enable you to see the clear sparkplug from a different angle than straight on, so I should be able to work off of the back deck of the boat.
Any shared experience would be greatly appreciated. Mostly, does it work.
Steve
