I cleaned out carbs, changed fuel pump, gaped spark plugs to specs, checked all the fuel hoses for clogs. Looks like a new coil pack on the bottom cylinder.
When I cleaned the carbs I did reset the slow speed needle back to 5/8ths of a turn from lightly seated.
The top cylinder is not receiving any fuel but the bottom cylinder does when I removed the spark plugs. Both cylinders seem to get spark. When I crank the key I set the throttle midway. The engine will turn over but won't start but it did backfire a few times.
I sprayed a fuel mixture into the carbs and the engine fired up but dies when I stop. Does anyone know what I should do now?
