Jamarine_73
- Jun 1, 2010
- 5
I?m new to the group but have thoroughly enjoyed researching and reading the various topics in this forum. I have solved the majority of my problems by simply using the forums here. That being said, I may have a good one for everyone!
Last year I purchased a 1991 hull that was repowered sometime around 1997 with a Johnson Ocean Runner engine. The engine runs fairly well (for an old 2-stroke!), but I?m in desperate need of changing the throttle cables and entire controls.
Knowing that in 1996 Johnson/Evinrude changed all the wiring harnesses, I assumed there would have been some modifications made to the harness when the boat was repowered. However, in my investigation I find that instead of changing the harness, they rewired the engine to suit the old controls! Instead of having the black control plug, I have a big red cannon plug.
I have looked through ebay/craigslist to find a suitable replacement handle (pre-1996), but haven?t had great luck. The local dealer has a few on the shelf, but they are in worse condition than mine. Attached is a picture of the original binnacle control.
Instead of going through the hassle of rebuilding the current set up, I have found that BRP sells a wiring harness to adapt Pre-1996 harnesses to the latest controls. Specifically, I was thinking about buying the current control (BRP # 5006186), using their adapter (BRP # 176341).
Does anyone have any experience with this upgrade? Will there be other issues that I?ll have to deal with (i.e. gauges, alarms, etc.) that will require additional wiring?
I?m hoping to avoid any unseen items that are going to complicate the experience. Any thoughts or insight would be greatly appreciated.
New Control: http://evinrude.cust.shopatron.com/product/0/5006186/_/Singe_Lever_Binnacle_Control_wkey
Wiring Harness Adapter: http://evinrude.cust.shopatron.com/product/84237/176711/_/Remote_Control_Wiring_Adapter
Boat
Make - Grady White
Model - 206G Overnighter
Year - 1991
Engine
Make - Johnson Ocean Runner
Model - J150NXEUC
Serial - G04280272
Year - 1997
Boat
Make - Grady White
Year - 1991
Engine
Model - J150NXEUC
Serial - G04280272
Year - 1997
