Re: Mercury 500 t bolt ignition
Ok, I will check that out and see if that is taking care of it.
I am not sure when the motor ran last time. I did get it with the Boat, which had a 65hp on it but lost one cylinder on that one.
If it would be the mercury switch, can i run the motor without it? what is that for?
I guess these switchboxes need to be replaced often it seems, so that is why i thought I check there.
Is there a test procedure for the Switchbox if the off switches don't seeem to be a problem?
I will be with the boat next week, but will not have any internet acess where it is.
Thanks for the tip.
