catchin'cats
- May 25, 2010
- 3
This may be a no brainer for a lot of you guys but I'm pretty new and don't mind asking something that I don't know. I am replacing the small 12 volt motor that runs the worm gear which in turn runs another gear which raises and lowers the prop, however in the process of checking things out i noticed that the clutch assembly and gear that raises and lowers the prop is in an oil resevoir and it is bone dry, so my question is what kind of fluid/oil do I use within this resevoir? Thank You guys a buch.
