J200 not running properly
DUTCHMANGOLD
Just rebuilt my j200tdexr is running strong.shut the motor for awile then start it will sometimes stall,or bogg down,or take right off.any suggestions
jonesg
Re: J200 not running properly
Try pumping the bulb before firing it back up to fill the bowls with cold fuel.
Also try letting it idle a few minutes before shutting it off, watch the temp guage to see if its cooling down at idle. Could just be heat soak.
