1998 DT 140 EFI. Enging new to me. First time out ran well for less than hour. Then started losing power and then died. Good prime the bulb and get a few seconds of idle out of it. Now oddly it seems like it will run longer in reverse than forward after some priming (how i got it back to trailer). 20 to 30 seconds before bogging down and quitting.
Pulled the fuel filter and the vapor sep filter. Both clean. Pulled apart the fuel pump. Pic attached of the findings. The diaphragm closest to the engine was intact but looked blistered on one side. Also, one of the clear plastic valves was broken as pictured.
Questions:
1. the pump obviously needs rebuilding, but would this be the cause of the symptoms described?
2. is this just an age related issue or would there be another cause for this type of failure?
3. the diaphragm rebuild kits i've seen only include the spring and diaphragms, not the clear plastic valve. I'm thinking i need a new pump assembly. Is that correct?
Thanks everyone in advance.
Curt
Questions:
Curt
