I ahve a set of 2002 merc 250 efi's and when i get up on plane they will run great for about 3 to 5 min at 4000 rpm and then the port motor cuts off with no warning. Restart and jump on plane and it could run for 20 min to hour or just cut off again. Replace raycors, motor filters, rebuilt fuel pump pressure tested fuel lines. switched fuel lines with each motor with no avail. Any ideas?
bndbob
bndbob
