hazelnutz20
- Jun 7, 2010
- 6
i have a 18' tri-haul fiberglass boat with a 1975 50 hp johnson model #50ESL75B. I have been out and the boat will only go about 12mph and the max rpm i got was about 3700. i have a 11-3/4" diameter with a 17" pitch prop. the throttle is opening all the way. I have been thru the carbs and everthing looks good. i went thru about 4 gallons of gas and i didnt go very far around the lake. i pulled the plugs out and there dark but it didnt smoke while it was running. all the hoses are alright and no gas leaks. it starts up just fine. i guess im just trying to find out if this is all im going to get out of this motor because i think i should get a little bit more out of it. thanks to anybody if they have sum sort of input for me to try
