After following this forum for a couple of days I have noticed a trend that is cause for concern. There are lots of suggestions for swapping carbs, intakes, and ignition systems. Although most marine engines are marinized versions of simple American automotive engines they are not automotive engines. A boat engine operates in a closed compartment. It often even shares that closed compartment with the gas tank. Gas fumes in this compartment combining with any source of spark can create an explosion that you would not believe. This happens more than you think. I have purchaced several boats that have exploded and burned to the waterline for parts. A marine carburetor is designed so that if the float sticks and it floods it vents the gas all down into the throat of the carb. The automotive version will spill the gas all over the engine. It then runs down into the bilge where it sits emitting fumes. Boats have flame arrestors on the carb to keep a flame from coming out in the event of a backfire. You are required to have a solid metal fuel line from the fuel pump to the carb. If you start swapping things around you will need to fabricate and new custom bent solid line. The fuel pump itself is different. There is ane extra diaphram and a tube that runs to the flame arrestor. If the fuel pump diaphram fails the leaking fuel gets sucked up the tupe and dumps into the cyliners. It's automotive couterpart will dump the gas into the crankcase where again it sits and becomes a hazard. Starters, alternators, distributors, solenoids, all of these must pass a strict test that the Coast Guard puts them through to make sure that they cannot emit an open spark. There is a reason why this stuff is more expensive. There is also a huge liabiltiy issue. when the lid blows off that boat and kills someone there will be an investigation. When they find those car parts or that rubber fuel line on there the search will begin to find who killed little Johnny. If a boat comes into our shop and it has automotive parts on it we either replace them all or send it down the road. With all due respect to all you Hot Rodders out there, be careful.
