Finally the surging problem is fixed. I hope this info helps
spinakersheet
Basically we took off the 4 bolts on the solex carb to get the the float there was an inlet valve that gas came through that had a piece of dirt about an 1/8" in size blocking the gas from being able to get in all the way.<br /><br />We took it off and presto it went from 3000 rpm's to 4200 and the surging problem disappeard. Also the flat spot disappeared at 1000 rpms.<br /><br />The other thing that did help and shot it from 2800 to 3200 rpms was getting a new vent it was 50% blocked with crud.
spinakersheet
Re: Finally the surging problem is fixed. I hope this info helps
I only have a inline plastic fuel filter. I am going to put in a good canister fuel filter/water seperator today to eliminate this from happening again.<br /><br />any hints or suggestions?<br /><br />Thanks
