intrepid
- Oct 30, 2002
- 50
Hi
I've owned the merc for 10 years and have decided to do an impeller changeout. I know you guys say do it every year but I was retriculant cause I never had the engine temp go above nominal. The boat is a 95 and this may be it's first impeller change. I got an impeller kit Mallory 948313 here from iboats. This kit makes me wonder if I should maybe xchange more parts than just the basis minimum that the kit includes for an impeller change.
What other parts or kit should I get to do a more thourgh change out , you know other small parts that may be worn out , or is this good nuf for now ?
This is a northern boat that only gets used about 30 hours a year
advise etc.? thanks
advise etc.? thanks
