I have a 1988 evinrude vro 60hp that runs extremely noisy. The vro system was removed due to porous pump and no new parts could be sourced, so I just premix now. Engine runs fine,starts first turn of the key but is just so noisy especially at idle. Its not as bad when running at speed but still noisier than it should be. There is also a slight vibration as you can see the engine shake at idle both in and out of the water. Any ideas what may be the cause of my problem. There is no tilt or trim on this engine either - is it possible to fit one to it ?
Any info much appreciated
IMO its like an exhaust problem,doesnt actually sound like anything is wrong,just very noisy.................has been running like this for 3 yrs now with no engine trouble................again just noisy
