warning beeps
dalton99
1990 40 hp mercury. not a solid beep, but a constant beep... beep...beep etc. as soon as you turn the key on and does not stop even after motor is running. bought the boat used and is my first boat. not sure what warning beep is for, need help. please? oil tank is full and motor seems to emit the blue-ish smoke like its getting oil, havnt run it hard or very long (not until i figure out what warning is all about). thanks in advance for any input on this prob.
fastback4
Re: warning beeps
Need to check 2 things i can think of. Water temperature sending unit, and oil tank level sending unit. Turn your key on and it should beep, and unplug the temp gauge wires first and if that don't work unplug the oil level wires next........Tom
dalton99
Re: warning beeps
thank you for the input tom. will try that and see what happens. thanks again!..... kenny
