FOuR BuOYS
- May 11, 2008
- 20
I have two questions the first is which way does the output shaft go, when removed from the bellhousing. I am assuming there are two bearings and two seals and should they be replaced when completing a rebuild engine.
The second question has to do with alignment when the engine and bellhousing go back in the boat. Should the big rubber seal be replaced on the bellhousing and how do you do the alignment?
I have pictures but not use where to upload them to.
Thank
Dale
Thank
Dale
