Glastron_V210
- Jan 28, 2009
- 324
Hey all. Anyone need a good laugh?
I bought an old boat 6-7 years ago.
At full speed the tach read about 4500rpm. I figured I had a bad tach. Engine sounded great.
Well two years ago the tach died completely. I don't use it too much, so who cares.
I finally got around to replacing it with a custom one I made. I calibrated it to V8 standards for hei...1 pulse per spark, so rpm = signal frequency*60/4 (sparks per rpm) I did this with a bench source to be super accurate.
So, I installed it, and at full throttle it read 4krpm! What the heck??
I just oscilliscoped the current into the dist, the 'tach' output and checked the rpm at different points. The engine is actually going that slow!!!!
So, I did have a bad tach initially, just not in the way I thought! I suspect I have the wrong ratio in the leg, 'cause it's a alpha 1 and should be a prealpha. I'll have to check it out the next time I pull it off.
At 4k I'm doing 35 knots (21' Glastron) so not bad...wonder how fast she'll go spooled up!
Chay
Chay
