Re: yamaha no power
ok, thanks rodbolt. I put the fuel separator back on,i checked the oil and it was full of gas and way!!! over full. I drained and replaced and also changed oil filter. I never run this boat more than half throttle and almost always under a load with 3 or 4 guys and bait tank and all that stuff. we usually fish at night dont go far. I have been watching the oil and noticed it is rising, will the oil level being to high cause one to bog down? the shift position switch makes sence because sometimes it quits when shifting from forward or reverse back to neutral, how do you adjust or check this switch. also forgot to mention once i was going down the lake before all this started and i hit the trim button and the motor cut off completely,
