26aftcab454
- May 12, 2009
- 1,510
1996 7.4 Mercruiser/bravo3--I replaced my alternator and now the belts squeal loud. -I checked to make sure the v-belts were in the correct grove- inside alt- center raw water cooling& tension-er-outside to power steering-
alt & power steering have moderate tension- the power steering brackets were loose- did i get them out of alignment?- the alt had several washers and think they went back the same.
every thing seems to turn easy. belts are good shape.
ANY ADVISE WOULD BE APPRECIATED
