The 115 Mercury was running on 4 of the 6 cylinders when I got it. I cleaned out the bottom carb and now is running on all cylinders. I took it out for a 10-15 min. drive and then came back in the harbor where there is a no wake. While coming in my motor would just die when you would put it in gear but when it was in neutral it would run. All my carbs are good to go. The gas bulb was also hard as a rock. What could be the problem?
For the timing mark on the distributor pulley and the fly wheel pulley do they have to mirror each other or should the lines/marks touch when cylinder 1 is TDC?
Any help is much appreciated
Travis
Travis
