Re: 1991 Johnson 150 no Fire
Check the stator and timer base resistance and DVA output as given below for BOTH banks:
WIRE READ TO RESISTANCE DVA (Connected) DVA (Disconnected)
Brown Brown/Yellow 900-1100 (35 amp) 150 V + 150 V + (*)
Orange Orange/Black 93-103 11-22 V 45-120 V (*)
White Purple (c) 100 V + (a) 0.6 V + (#)
White Blue (c) 100 V + (a) 0.6 V + (#)
White Green (c) 100 V + (a) 0.6 V + (#)
White Purple (2nd connector) (c) 100 V + (a) 0.6 V + (#)
White Blue (2nd connector) (c) 100 V + (a) 0.6 V + (#)
White Green (2nd connector) (c) 100 V + (a) 0.6 V + (#)
Wht Blk/Wht (2nd connector) 215-225 6-12 V (b) 6-12 V (from pack)
(*) This reading can be used to determine if a stator or pack has a problem. For instance, if you have no spark on any cylinder and the
stator?s DVA reading is out of spec ? disconnect the stator wires and recheck the DVA output. If the reading is still out of spec ? the stator
is bad. If the reading is now within spec ? the pack is bad.
(#) This reading can be used to determine if a pack has a problem in the triggering circuit. For instance, if you have no spark on one
cylinder and the timer base?s DVA reading for that cylinder is low ? disconnect the timer base wires and recheck the DVA output. If the
reading stays low ? the timer base is bad. If the reading is now within spec ? the pack is bad.
(a) Check stator DVA first. Then if timer base DVA is 0.6 - 1.5 V, the pack is faulty. If below 0.6 V or 1.5 - 99 V, the timer base is faulty.
(b) DVA will drop below 1 V when the engine drops out of Quick-Start (engine is over 104 Degrees or 1200 RPM).
(c) Use a comparison reading as different brands of meters will give different readings. The typical range is 1M to 5M ohms. As long as
you have approximately the same ohm reading on all six tests and the correct output with the DVA meter, the timer base should be good.
Remember that temperature will affect the readings. The exception would be if one of the SCR?s inside the timer base is breaking down
while the engine is running. This can be found indexing the flywheel and checking the timing on all cylinders. If the readings are off,
reverse the meter leads and retest to see if the readings are corrected.
You may need a DVA adapter, if you don't have one:
http://www.usatoolwarehouse.com/usatoolwarehouse/ESI-640.html
