I have attached some photos of the flywheel and points. Want to know how to set the .020 gap. If I put the flywheel marked T within the double line and set it and then move the throttle at all it really changes the position of the double marks and changes the gap. If I put at setting B between the two marks, neither set of points is open at all.
Obviously, you must have correct throttle position for each setting. Wondering if anyone can give me the proper way to do this setting.
Thanks
Leefy
Thanks
Leefy
