trobinson017
- Sep 12, 2004
- 183
Hi all,
A couple months ago I rebuilt one of my carbs (Johnson 130) and the boat's been running great. So I bought 3 more kits to rebuild the remaining carbs which I did yesterday. All 3 at the same time. Maybe not such a good idea in hindsight because now I can't get the engine to keep running and I have 3 rebuilt carbs to troubleshoot. The engine starts fine and seems to run for about 25 seconds, then it peters out. Very similar to when there's water in the fuel, but I've checked and there's no water. After the first couple of runs like this it's hard to start, like it has to sit for a few minutes before it will start again.
Prior to this test I pumped the bulb to make sure none leaked. Well, 2 of them did; one from the float bowl gasket and one from the overflow hole on the float bowl part. I took them both apart and resolved the leaks. The overflow one has me concerned because it was stuck which is why it leaked. I loosened it so that it would move and not drop below the float bowl gasket level when inverted. But maybe it's getting stuck in the opposite position? I just checked all three float bowls and they had fuel in them.
Any ideas on why the engine won't keep running? Do all 3 rebuilt carbs need to be adjusted? I put them all back on the same places they came off of. I'll take the one that was previously stuck back off and check it out. But if that's not the problem then I need advice on what to look at next. My factory manual isn't' helpful for this issue.
Thanks!
Thanks!
