Re: 90hp force won't run past 4000rpm
Yes a an intake leak can cause it to run lean. Make sure all the bolts that hold the carburetor adapter to the block are tight. With it idling, you can take some carburetor cleaner and spray around the base of the carbs and carburetor adapter. If the motor changes idle speed, you may have found a leak. Be careful not to spray directly into the openings of the carburetors. The cleaner has a tendency to wash away the lubricating oil that is mixed in with the gas from the engine bearings. Same thing applies to starting fluid.
Make sure the vent for the gas tank is open and not plugged. You can test by opening the gas cap just enough to allow air into the gas tank.
