The motor is a 60's 18hp evinrude and recently started coming out of gear(slipping) in forward gear. It seems to gradually work its way out of gear and then immediatly slams back in to gear. I put my hand on the shift lever and could feel it backing out of gear until it re-engaged. With the engine off the prop doesn't turn when it is engaged, so I'm not sure what's goin on. Bent shift rod? Any info helps.
Thanks,
Mike
Thanks,
Mike
