I have a 1979 Merc 70 that I am going to mount on a SlideMaster jack plate. The SlideMaster has a 10' setback but instead of two bolts on each side that are able to slide up or down, it has 2 bolts on each side that do not allow for adjustment(unless new holes were drilled), is this still considered a jack plate? the back of the "jack plate" has holes already drilled in it for mounting the motor. Which holes on the motor do I use for mounting the motor to this plate? The motor has 2 clamps for mounting, in my application are these still used? If so do I need a spacer of some sort to clamp to because it seems the jack plate is too thin to screw the clamps down on. If I didn't explain myself well enough, let me know, and I'll try and take better pics.
