I have an Evinrude 25hp from 1985. The throttle goes so far on the side of the outboard before resistance is met from a spring or something similar. I am guessing, as there was a tiller arm attached when I bought it, this is because of the tiller arm.
The throttle will go further but if let go will spring back to a low rev position.
How do I disengage the spring to enable smooth acceleration use by the remote rather than meeting this resistance everytime I try to push forward on the remote.
Just been looking through other posts about a similar problem.
The remote isnt attached yet, the stiffness/resistance I am encountering is when trying to move the throttle lever by hand on the side of the engine.
