First Post here so hopefully the dog pile is not too bad.
I was just gifted my old mans boat a 1985 Sea Ray Seville, 21ft cuddy cabin. It runs fine, however it has sat in Arizona for the past twelve to fourteen years. I have now brought it to Florida to use up here in the pan handle.
Question one which is my actually technical question-
1. Engine year-85? 4 cyl GM 170 HP, model-MCM 170MR, and serial number-A495158.
2. Type and model of outdrive, Mercruiser I/O
3. The problem I have with the boat is that when I go into reverse from neutral it will slip with a grinding noise and not set into gear. Sometimes it will go right into reverse(i.e. forward to reverse relative quickly) however when in neutral say drifting towards dock it will grind when put in reverse more often then just setting into reverse. The outdrive was rebuilt about six years ago and the boat only does a few lake trips every summer.
Question 2- I know there are a bunch of threads talking about winterizing and summerizing boat but, I know the boat has been neglected its require maintenance however due to it being not used allot and stored in a desert the results have not yet shown. What is a good place to get started maintenance wise and something?s I might forget to do bringing my boat from a lake environment to the Gulf? Links are more then welcome.
