concentric
- Apr 25, 2010
- 19
Hi
Struggling with my rebuilt qudrajet, and it is improving.
But something is littlebit wrong; just before the seconaries are opening the reponse are very flat. I dont know which way to adjust, is it a lean condition on primaries or ? Its not the windup spring thats holding back its the vacuum valve, and probably it takes a little bit to long time to reach rpm to let the low vacuum realse the valves. When the secondaries open its all right.
Also if I push the throttle to max from standstill it will accelerate fine until i reach the flat spot, and then i have to pull back a little.
OMC Cobra 1988 5.7l, 260 hp
prim 71, rod 45, second rod CL, Hanger E
