I have a 1986 50hp Force that needs rebuilt. I checked the compression and it was 90lbs in the top cylinder and 80lbs in the bottom. The engine recently stopped running and now backfires when I try to start it.
What other year models of powerheads will interchange with my mid and lower half of the engine.
I found other year models of powerheads but not a 1986.
I thought of replacing the pistons and rings, but I would have to split the case to have the cylinders bored, then I would need a powerhead rebuild kit, which cost alot more than a good used powerhead.(I can't find a kit for a 1986 anyway)
Thanks for any ideas you can give me.
