Re: Stator does it provide the spark
When you say "no reading," do you mean "infinite resistance" or "no resistance"?
My book says that for low-speed windings resistance test there should be 5400-6200 ohm between red and blue leads.
(Although I have been told on this forum that the book is wrong and that reading should be taken between blue lead and powerhead ground...)
Either way, check it again, both between those leads and between blue and powerhead. And make sure your meter is in the correct ohm range. If it is infinite resistance, then the low speed windings are broken for sure; if no (or extremely low) resistance, the windings are shorted to ground.
As stated above, DVA testing the actual voltage output on the stator is the definitive test; however, if you are truly getting infinite or (near) zero resistance, then the stator is definitely shot.
EDIT: and yes, the stator makes the power that the switchbox distributes to the coils (as timed by the trigger), which then fire the spark plugs...so if bad stator, then weak or no spark.
